Johnny C
I had the ABS system replaced a year or two ago. Sensors and 'brain'. Since then, if I press the brake pedal slightly the ABS kicks in and pulses the pedal. 9M have looked at it several times and are still scratching their heads. Also when I've been doing low, constant revs for a while (say in a traffic queue) the ABS light comes on. Turn the engine off and back on and it goes out.
When the alternator went recently (and battery got flat) the pulsing problem with the pedal went away for about the first 20 miles. It came back, but yesterday after the engine loom was replaced, the pulsing problem also disappeared temporarily.
Now I'm only a simple soul with little technical knowledge, but it seems to me there could be some capacitance building up, and when all the electrics are disconnected that drains off. It doesn't drain off when the ignition is turned off.
Is there any way of earthing the ABS system? Would a Bosch specialist be able to tell me what's wrong?
