TTM
Well-known member
Using a GTX compressor with a KKK turbine would make sense if the compressor output is such that it will not choke the turbine. KKK turbines are known to be a lot more restrictive than GT turbines, which may mean you would need to use a "rather large" KKK turbine with a "rather small" GTX compressor in the hope to level out turbine inlet pressure (TIP) with peak boost (PB), for a fixed (engine size ; PB) couple.
A few people have actually measured back pressure. Vic Timpauer in this thread posted his results using a GT3076R/0.63 on a 2.5 engine, which suggests to me that going for a GT30 housing larger than 0.63 on a 2.5 engine may bring nothing but lag.
I am getting a 1,1 TIP/PB ratio with GTX3076R/0.82 on my 3L engine, which tells me this compressor and this hotside are very well-sized together considering my boost level of 1.2 bar.
TIP is very simple to measure and anyone with some heat-resistant hose, a boost gauge and a couple of clamps can measure it on their own cars, using the CO test port tube on the cross pipe. Since the TIP/PB ratio may vary with RPM, it should also give an indication on how well the engine is breathing in function of where it's running in the RPM range.
