PSM Failure / just changed battery?
SamanthaHewit
If you have just changed your car battery (possibly applies to charging a really really dead battery too), you might get a warning message saying PSM FAILURE.
Dont worry, this goes out after you go for a little drive.
This information might save you panicking like i did earlier today!
xoxoxox
ORIGINAL: SamanthaHewit
xoxoxox
and did you also reset your windows ? [&:]
In my experience, a dying battery (<11V) can also cause: spoiler raising; dash lights coming on and staying on even with the ignition key removed; and alarm triggering. As a personal observation, Porsche branded Moll-sourced batteries seem to be particularly prone to early failure. A.
I heard that batteries for my car were supposed to be expensive but mine was only £85 i don't think that's expensive at all
That would depend on if you fitted a Porsche branded one or not.
Whats the difference? The new one looks the same as the old one, and the numbers are the same too.
Sorry, where did you get the battery from?
Porsche only approve/fit the dreaded MOLL battery and won't tolerate the fitment of any other battery if the vehicle is covered by their warranties (original or Porsche Approved).
Presumably yours is a Bosch, Exide or Varta battery; most likely a superior product compared with the original fitment.
Thats what the man in the shop said, he reckons that Porsche batteries being smaller make them more susceptible to failure. I got a 3yr warantee with my new battery too.
The strange thing with my battery failure is that i never once got an error message on my dashboard. I get them whenever a door is open or if a bulb is gone or if there is an engine fault, but not for battery dying... I would have thought that would be an easy one to create an error message for?!?
I'm not sure about Porsche batteries being smaller Samantha - the battery in my Cayman's a 120Ah monster.!
And yes, you'd have thought that it would be fairly straightforward to sense a consistent battery low voltage fault. However, the logic would have to trap out voltage drops when starting, turning on lights, etc., otherwise the fault light would be a permanent feature on the display..!!
Just resurrecting this thread. I have just changed my batery yesterday (2009 2.9 Cayman) and I am still intermittently getting the PSM failure light, even after driving it 4-5 miles. I have an iCarsoft POR 3.0 to check and erase the codes, but that does not seem to work.
Any clever ideas?
Normally any warning lights disappear as soon as you start driving after a battery change.🤔 You may need to reset the window limits too.
Assuming there were no problems before the battery replacement, other than turning PSM off and on a few times and/or trying to get your diagnostic analyser to work I can’t suggest a way forward.
Any clever ideas?
What doesn't work?
the scanner ? or clearing the codes?
If you are getting codes - what are they, if they are coming back then they are reporting a real fault.
