Hello gents
Yesterday my clutch pedal sank to the floor. Fortunately I was just yards from home when it happened - managed to get the car into the garage and decided to get a head start on replacing the master and slave cylinders by removing the old items first.
Car jacked up, on stands, starter motor off, slave cylinder off, no problem. Master cylinder unbolted from bulkhead. So far going well until I got into the footwell to try to detach the master cylinder from the clutch pedal. According to the Clark's Garage instructions - albeit these are for LHD cars and mine is RHD:
On late 944s and 968s, once the spring clip is removed, push the clevis bolt out through the right side (to your left as you do your gymnastic routine on your back under the steering wheel). The master cylinder push rod / clevis should now be free of the clutch pedal.
Circlip and two washers duly removed, but the bolt is firmly budged in. There's not enough room to get a mallet in there but I've tried banging the end of the bolt with various implements without luck. There's also not enough free play in the clevis or cylinder to simply lever it off the end of the bolt.
Am I missing something?
