PPF
satusai
I have just bought a fab 2018 991 GTS coupé that was fully wrapped by Topaz Bristol back in Dec 2021 using their own brand that only had a 5 year warranty. The PPF looks to be in exc cond but as this is my first car with PPF any advice on best products to use to clean the car and wheels that have PCCBs? Research has suggested CarPro Reset Intensive Shampoo, P & S Brake Buster and Angelwax Elixir Tyre Dressing...thoughts?
Topaz often finish PPF with Gtechniq Crystal Serum Ultra that has a 9 year warranty. It's a strong ceramic coating that shouldn't need any enhancing polish. I just use Bilt Hamber pre-wash foam on low pressure, leave for 5 minutes, rinse, then hand wash with diluted baby bath (Ph neutral) on a wash mitt, finally finishing with a power rinse. Dried off, it always retains a showroom finish.
If you have centre-lock wheels, take care washing them as some preparations (including Gtechniq) seem to react with the wheel bolt surface coating, causing discolouration.
Regards,
Clive
Everyone will have their favourites but I use Gtechniq products.
As you have older PPF you might consider having it "mopped" (lightly buffed) to improve the top surface and then ceramic coated. It makes keeping it clean very easy.
Regards,
Clive
Good point on centre locks, I just use the car shampoo and clean the wheels frequently to avoid build up on brake pad dust
You need to remember that the 'warranty' is the maximum that the manufacturer will offer based on ideal situations and care. I have found that a 5 year ceramic coating was done after 2, not on my car but a friends. You may also find that if the hydrophobic properties start to slow, it may need a chemical decontamination with an Iron/fallout remover and/or a tar remover and even a water spot remover but take out any contamination thats bonded to the paint and PPF.
You can polish PPF and Gyeon do a specific polish just for that but speak to Topaz and see what they recommend. You can buy decon shampoos from all the major brands such as Gyeon, G-Techniq, Clean by Pan etc but it may be worth seeing if Topaz have their own as their products may compliment their PPF and ceramic coating. Just remember that if you polish a PPF you will need to reapply a ceramic coating. Use the softest Pad you can find on a low to medium speed with virtually no pressure, just the weight of the machine should suffice but I'd go down the chemical decon first.
I'm not a professional but an enthusiast. Do a test spot first and see how you get on... all at your own risk of course.
Dan
Thanks everyone for your responses. I have ordered some Garage Therapy and YumCars wash from CA Detailing and will see how I go.
Just as an aside - did you tell your insurance company about the wrap / ppf - there are a few who class it as a modification and refuse cover ( Admiral being one of them).
Not correct. I’m with Admiral and they have no issue with PPF. You just need to make sure it is noted on your policy.
Aviva however, don’t insure cars with PPF.
Dan.
So “not correct” in the example I have but factually accurate in that some insurers won’t cover cars with ppf or wraps.
Therefore, my comment may still prove to be helpful (or not) to the original poster who may want to check with their insurer.
Yes, some insurers may not cover PPF and it is best to check but you gave Admiral as an example which wasn’t correct and may have resulted in the OP not obtaining a quote based on that.
Dan.
Dan.
I meant my reply to be helpful. I wasn’t expecting for one minute that the original poster would take the words of a well meaning stranger as a definitive guide to the operation of any particular insurer.
Nor to be honest was I expecting a terse “not correct” when a “you sure about admiral, perhaps you meant aviva” may have sounded a lot less like my homework being marked and more like a friendly informal forum.
I will be sure to avoid the possibility of making a mistake in the future and if I need pedantry as a service I know just where to come.
You are right.
I was wrong.
I guess you score some points.
