Yesterday the car took up smoking in the extreme. When I took a look under the bonnet I found power steering fluid had got all over the last downpipe, the bulk head end of the engine bay, and was merryily smoking. I could wipe it off some of the hoses in that area and the cam cover (?? bit with Porsche written on it).
The power steering pump has had a weep ever since I bought the car but this was a bit more extreme, so have cleaned it up but I couldn't see anything obvious. I had topped the reservoir on Sunday morning and was in a rush so I wonder if I over filled it and it has blown out of somewhere. On having a look around I found this pipe (circled in red) that looks like some kind of breather/over flow from one of the pipes coming out of the bottom of the reservoir. Could this be a reasonable cause?
I had planned to do this work on Sunday but never quite got there, I have had a couple of oil leaks, one from the oil filter and still have to replace the pressure sender, plus when I changed the oil filter I got oil everywhere, so I took the under tray off and gave everything a good clean up. During this I notice the pipe on the power steering pump, circled in the pic below. THere doesn't appear to be a clamp around this pipe, should there be?
I was also looking through the manual and noticed that the 944 should have a smooth sump and the turbo one with fins. Mine has the one with fins on, but I assume that at some point they used this on all cars.
If it's any help you can buy new hoses from Porsche; the feed is about £30, whilst the return is about £130 (believe this is fabriacted into the cooler) - I ended up cutting about 1cm from the top of the latter hose and resealing with a new hose clip. You can also buy new seal kits for the pump for about £20 - check post in technical section for youtube vid.
