Power Steering Fluid
- Thread starter Big Les
chrisg
having changed one of the PS hoses on the Turbo recently, I don't think its too difficult. Simply drain all the old fluid out and then replace with new fluid. Just make sure there's fluid getting to the pump before you run the engine at speed.
It might be worth gravity draining the PS fluid out from the reservoir = banjo bolt fitting on the drivers side of the pump, then turn the car over a few times (without starting) to get the rest of the fluid back into the reservoir.
C
chrisg
once you drain the reservoir (~ 1/2 litre) yes, you're correct there will be quite a lot of fluid still in the rack, pump, pipework and the PS fluid cooler - square coil of 3/4 loops in the front bumper on the drivers side.
Turning the engine over without starting it should push this through.
A5DSR
I just have a bit of 'no-mans' land play when dead straight at motorway speeds. God knows where to start here, possibly tracking alignment checks.
I don't have a film on the bottle, just a dribble all down the inner wing. The re-connected hose should sort this.
There's a bit of a discussion on the Titanic listing at the mo about tie rods and their ends. It may be a place to start with sorting out that there play. About £60 a side, by the sounds of it. (I'm getting a quote from a reliable supplier I use called frazerpart, and they may be a smidge cheaper. I'll keep you posted if you like.)ORIGINAL: A5DSR
robwright
robwright
Hilux
Fill up and the system should bleed itself.
Not that I did it mind......................if the fluid is a nice pale red colour and doesnt smell off its probably ok (after all auto gerabox oil takes much more of a pounding and sits there for years)
sawood12
944's seem to benefit from fairly regular replacements of PAS fluid to stop the groaning noise when going full lock at low speeds. But usually you can get away with fairly infrequent changes of fluid as the system is fully sealed so no moisture or dirt gets in. I should think it is one of those jobs you maybe should consider every couple of years or so.
The main thing I noticed was that the steering feels much smoother and a lot more responsive...
Dave K.
Big Les
ORIGINAL: robwright
Never done it on a 944 mate but usually find the lowest point you can and drain it with the resevoir top off. Then fill to a little above the max mark and operate the steering to full lock on either side to bleed it and rid of all air bubbles. Then check and adjust level if necessary. PAS and ATF pretty much the same thing mate as far as I know. When I was in the Army we just called it cherry lol... Don't think it makes that much difference for normal use. Unless you are using a load of stop leak as I am at the moment. LOL it's like gearcase grease and it don't like the cold in the morning.
appletonn
ORIGINAL: sc0tty
ORIGINAL: sr.944man
Handy tip for this job and any other job where you want to move the steering with the wheels on the ground: put a glossy magazine in front of each front wheel and drive onto them first. Takes all the effort out of turning the wheels. Ruins the mag though, so use someone else's.
At last, a good use for porsche post !!!
Or perhaps a copy of Scotty's newly published guide "How to win friends and influence people"?! [8|][8|]
