I have put in *phone* chargers in loads of cars, though having tried to do it in my 997, and seem to be running into an issue…
Basically, running a fuse jumper / adapter against a couple of different fuses (which are ignition switched), though in both cases the charger charges *a phone* for a second or so, and the switches off, and so on…
I have tried a different cable and different *phone* charger, and have the same issue - the power seems to drop in and out…
I wanted a power that is switched so there is no drain when car is left in the garage for say a week without use…
Has anyone had this issue? Has anyone hardwired in a *phone* charger successfully - and if so, which fuse/location did you use?
