Posting Pics ?
Frenchy
Right Gents,
What is the best way to post pics on this forum ? let me know and i will get a couple of pics posted on my duo of 944.
Do you have them hosted on the web somewhere (photobucket etc) , dont wish to be rude dont know your level of knowledge ?
http://www.englishmastiff.org.uk/gala21s.jpg
Theres two options here for you for starters , if you have the image hosted on the web , you can just cut and paste the web address for the picture in to your post , you dont even need image tags as this forum will see it as a web link due to starting with www etc.
Or when you are putting on or editing your post use the upload files button just below your text box left of centre and the forum software will upload your pic
( if within its size limits) and create a small image called a thumbnail in your post.
Folk can click on the thumbnail which is a very neat ( and server load saving) way of doing it. There are other ways :p
Regards Mas
Dead easy - upload them to photobucket (you may need to create an account), copy the "Direct link", click on the yellow "mountains" button and paste the link into the box.
Like this [:D]
Mastiff,
No not posted on the web, just have them here on my C drive. I am reasonably ok with IT , i beleive it is better to place them on photobucket or similar and the create a link ?
Not too sure about creating a link though ?
If it was me m8ee and I was in your position I'd probbaly use the forums excellent upload facility that I described, you cant beat it for simplicity.
As for creating a link , most of the free services like photobucket want your 'business' and will include a set of links with each pic so you just literally cut and paste the link in to the box that you get by clicking on the
' mountains button' as the chap rightly mentions in the post above.
just make sure if you use the mountains button that the link startds with the whole http:// not just www some [&:] forum software is fussy re that
If you get in any probs mail me , I'll even host a few if your stuck
Regards Mas
I will try the thumbnail method,here go's
Nope, coming back with file is too large message ?
Mate - used the trial and error method and ended up writing some detailed notes once I had figured it out. See below:
Step 1: Set up photos so you can share:
- Upload your photos to www.photobucket.com
- This is very easy to do. Just go to website, register and upload your photos from your pc
Step 2: Selecting the images you want to post to the forum:
- In photo bucket, click on the image you want to post to the forum. As advised by John, due to size look at including max 3 photos per post
- Once the image appears in photo bucket you will see at the bottom left a table title "Share this image"
- This table has 4 options:
- 1. Email and IM
- 2. Direct Link
- 3. HTML Code
- 4. IMG Code
- Highlight the option 2 "" "Direct Link". Control C on the key board will do this. You should have highlighted a code similar to this: "http://i589.photobucket.com/albums/ss336/andrew_churcher/IMG_3341.jpg"
Step 3: Adding the photos to the forum message
- Open and log into the forum.
- Either click on "Post reply" or "New post" "" depending on what you want to do
- Clicking on either will bring you into the "Post new thread" screen
- In the "message" box "" you will be entering the photos.
- To insert the photos you must click on "Add Image" button. Its in the tool bar directly above the message box and its at the far right hand side. (It's the square yellow box with what looks like 2 mountains in it)
- Click on the "Add image" button
- This will then bring you to the "Explorer user prompt"
- Delete any pre populated data. Ie: It may show http://" just delete it
- Now Paste your "Direct Link" (which you copied in Step 2 by "Contol C" on your keyboard) into the field "Enter image URL". Do this by keyboard control "Control V"
- The URL link should appear like that above:
- http://i589.photobucket.com/albums/ss336/andrew_churcher/IMG_3341.jpg
- Click ok
- The image will now appear in the Message box as a photo
- To add additional images:
- Hit enter twice after the first photo (put the cursor at the bottom right of the photo) as this will make sure the photos down the page (1 under the other)
- Click on the "attach image" button
- Copy a new image "Direct link" from photo bucket
- Paste the image direct link into the Explorer user prompt
- Click ok
- Then repeat.
