bmnelsc
Hello - need to replace the voltage regulator on my 91 S2 with air con. Removing the alternator is quite a job with removal of AFM and cooling hoses, etc. required to access the alternator mount and then moving the cooling fans to remove the alternator mounting bolt. Anyone replaced their regulator with the alternator installed? Looks tight to get the air shroud off but assuming it will clear can the regulator be changed without having to remove anything else?
