hi, can anyone recommend a good supplier of engines for my porsche 944 turbo. i have made a lot of mods and it is 280hp at moment but it should be a lot more. seems like the bores and rings are worn as it only has 100psi in 2 of the cylinders and 15o psi in the other two and anymore boost i put through than 1 bar just blows more oil out the exhaust without horsepower gain. it runs fine all be a bit laggy at bottom rev range but burns a litre of oil every 100 miiles on a track day and every 400 on road. i think it is time to change the block or rebuild the one i have so after some advice on where i should go. i probably can change the block myself but rebuilding it i think i will leave to someone else. also i am thinking i might go bigger whilst i have to do this job and heard of 2.7 and even 3 litres that can be made for the turbo. what do people recommend?
the cylinder head has been rebuilt in the last 5k so i don't think it is the valves or stems and i have a rebreather chamber to reduce the crank pressure so this is why i am thinking rings and bores.(it has 150k and the last 20k have been nurburgring trips and track days)
thanks
thanks
