Porsche 911 3.2 won't start
ramiro.elliott
I hope you can help me. I was driving a 3.2 on Sunday and then parked it in the garage, but unfortunately, it wouldn't start yesterday. No spark... and no fuel as far as I can tell, because the spark plug was completely dry.
I've already replaced the DME relay on the other 3.2. The ignition coil has continuity.
Then I checked the ignition coil and the ignition coil and couldn't find any continuity in either. To be sure, I also checked the second working Carrera and the result was that the ignition coil and DG also had no continuity.
Does anyone have any idea what I'm doing wrong, or whether all four are actually defective and the second Carrera is still running smoothly? The next step would be to replace the control unit.
Thank you in advance for your answers!
Hi, you could try contacting our Technical Advisor, Charles, and have a chat. Find his contact details in the Club magazine p125 of the March 2025 edition.
I don't see your car/s on the Register, if you can please add them to your Profile.
Steve
Dexsport Australia
On the 3.2 Motronic, no spark and no fuel usually points away from the coil itself and more toward a reference signal issue. I’d check the reference and speed sensors at the flywheel next — if either of those isn’t sending a signal, the DME won’t trigger spark or injectors, which would explain the dry plug. Also worth confirming you have 12V at the coil with ignition on and that the DME relay is actually powering the ECU and fuel pump circuits.
