Giles, A thread entitled "Poor Timing" on here could mean any one of several things, including that your cam belt has just broken. So things could be worse ... Scratching my head, the only thing I can come up with is that some flaps in the heater system are powered by vacuum lines. This diagram (and labels) may be helpful;
Number 5 is "Vacuum line for heating valve". This may be a common line with the brake vacuum assist line (they may T-off each other somewhere). If so, a broken line somewhere or split hose may explain the symptoms you have. Keep us posted. And I hope the wedding goes well. I've been Best Man three times and both loved and hated each wedding in equal measure. Oli.
