After the heavy rain, Iv found my sunroof is leaking.
It leaks from the lowest corner, which ever way round I park.
I can see the drip build up till it drops from inside the car. It builds up in the corner off the sunroof where it meets the headlining. I'm not sure if it's dripping from over or under the sunroof lip sill( the inner sill on the car body )
When I brought the car I noticed the sunroof didn't sit completely flush with the body, and I could press the corners and short sides off the sunroof in. Which would then pop back up straight away. So I tryed swapping over the sunroof with my other 944 2 try and trouble shoot the issue. Trying differnt combinations off sills e.c.t
Neither really worked, but it was slightly better.
Now I have noticed some cabin noise while driving, faster you go the louder the noise. If i push/ put pressure on the back off the sunroof from inside the car while driving the noise increasse, so I'm thinking the sunroof isn't completely tight.
Also the sunroof switch doesn't stop at a closed limit. It can go from open 2 closed 2 retracted in one move, regardless off the ignition position, so while on the move I can retract the lifting arms, which is wrong.
So when I close the roof I do it in small adjusement.
One issue, set the limit switch right?
Now Iv allso noticed play in the lifting arms when the sunroof is completely erected. And when the sunroof is removed and the lifting arms fully extended, ( have 2 press the micro switch in 2 allow this )
So is this normal 4 there 2 be some play in the lifting arms? I took it all apart and everything is there, all 5 screws and the washer b4 the cog. The lifting arms theet looked ok and so did the cogs. I replaced the cogs with new ones anyway. There still play. I'm wondering if it's this play that's not allowing the right amount off pressure when the sunroof is closed.
The plastic trays which the lifting arms slid into seem of, they have split a little but don't look worn where the pin sits. Iv tryed adjusting these up and down 2 create less play when the arms are shut. But no joy.
Can you please check your sunroof 4 play and let me no if this is normal or likely 2 be the cause off the leak/ wind noise.
Thanks.
Thanks.
