petrol
- Thread starter Guest
jamescharnley
** this applies to the 2.4 MFI motors in 911's that had lower comp ratio than the 2.2's
Evil J Guano
Jon Darlington
How is the engine running? Have you had it on a rolling road yet[
I use optimax, I think it gives a smoother pick up although that could just be me wishing.
Evil J Guano
Jon Darlington
Sounds like it could be your idle jets, have you taken them out and checked they are not blocked?
Evil J Guano
May have leak around the shafts?
Failing that hows the ingnition system: dizzy coil reg leads plugs
912UK
remove carbs reface the bottoms to make sure they are sealing as per the Dwane Spencer book
Balance the split shaft as they may be opening dirrently (b***ly split shafts)
New gaskets back on the manifolds
screw in the idle jets and turn back 1.5 turns on each one
leave one side of the accelrator linkage off and run the car check the balance of the carb on the one side and then move over to the other set and adjust to match then reconnect the linkage and check to see if it is the same if not adjust the linkage arm until it is .
This is a good starting piont and from there I don't know other than a proper tune up but since I been learning from the man Mr Lucas It's not going to be far off from there.
but need to consider points ,plugs ,valve clearance ,heads in good order eg not carboned up (like mine) and the float levels ....
Gosh I knew none of this 9 months ago.... [
Jon Darlington
