PDK on track
- Thread starter TonyRSR
penguinman
My previous extensive experience at Knockhill was with my CR manual, so I am looking forward to comparing the two transmissions on a track I know very well.
On the road, I use Sport all the time, and shift the gears manually using either the paddles or the central stick shift. On the track I can choose to change up a gear at around 6500 - 7000 rpm. I would expect the Sport Plus mode to be the most track focussed option for setting the best lap time, but I shall be testing all the options, including "D" mode with Sport and Sport Plus engaged just to see how it relates to the corner speeds. I shall also test the Sport PSM traction control setting, which is a new map on the 718.
It should be an interesting day, and one which I shall be reporting back on, after the event.
Brian
Steve Brookes
Moderator
