I’m 2 weeks into my first experience of PDK in my 987.2S so just getting to know it. I’ve just reset it to factory settings so it can start to learn my driving “style.” One thing I’ve noticed is a very slight jerkiness in the gear changes when the box is cold, when in automatic. Is this normal? After 4 or 5 miles when the car’s up to temperature and warm fluids have been circulating the gear changes are very smooth, which seems normal to me but I thought I would check with you guys. The PDK has just had its 12 year service so that shouldn’t be a consideration.
PDK BEHAVIOUR FROM COLD
- Thread starter michael.williams1
My second Boxster was a 987.2 with first generation PDK and it exhibited the same characteristics.
Normal in my experience of a couple of 987.2 pdk cars. It’s a performance box and it works better when it’s warm.
Btw as far as I know there isn’t a actually a reset for “learned driving”
The procedure often quoted “turn all loads off - hold it in gear at standstill etc” is torque slip calibration and is only applicable to macan gearboxes (which are VW DSG derived ) and it’s documented as a a step when you disconnect / reconnect the battery on those cars.
That process is not listed for any “sports car” pdk model.
According to the tech briefing that came out when the pdk was 1st introduced they adapt based on the most recent driving -literally how you drive into the last few corners, braked or accelerated into the roundabout - they take notice of altitude, yaw, steering angle brake and accelerator input over a small window.
Otherwise every car would drive like it’s just been bought and driven off the forecourt and is being run in.
There are recalibration routines that can be run from diagnostics but that’s more about “fixes and updates” than “reset learning or adaptations”
So this procedure I read about doesn’t actually work on a 987.2 then(?). I ran it yesterday and I was convinced something had changed but maybe that was a kind of placebo! …
1. Turn on the engine, turn off A/C (and any other systems like PCM radio etc) and let the engine run for 3 minutes.
2. Turn on A/C and wait another 3 minutes.
3. Turn off engine, remove the key, close & lock the car and wait one minute
4. Restart car and PDK is now reset to factory default
That’s the torque slip calibration.
As I say it’s not specified in the docs as something for 987.2 only ever seen it for Macan. In that case it’s so the gearbox can reset on of its adaptations if the the battery has been removed.
I tried it on my previous car. Didn’t make any difference there equally it didn’t do any harm.
I haven’t seen anything in the factory documents that suggests there is any kind of long term learning going on in the pdk, it adapts “in the moment” to how you are driving and the inputs from the various sensors. If you brake heavily before going into a bend it will choose to downshift 2 gears not one and for the next few seconds will shift more aggressively / quickly / higher in the rev range. If you “calm down” so does it.
from a cold start the car will use an ignition and gearbox map that is designed to rev slightly higher to promote faster warmup to operating temps - I suspect it’s this function combined with cold fluids that makes it feel a little more industrial for the first few mins.
That’s very interesting and makes a lot of sense. Thank you.That’s the torque slip calibration.
