PCM 1 Screen
- Thread starter ramponi
Hi,
The PCM1 has 3 setting for display as followsing with the different functions.
Auto - when the headlights are on, it turns into night mode and dims (assumes its dark outside)
Day - Bight Screen
Night - Dimmer screen
I have also noticed that the screen also adjusts a little according to how much light there is in the car to further enhance the Auto settings. You will see a little white 'blob' which is the senor at the top of the pcm unit. Putting my finger over it brightens up the screen.
Question..... ?
Can you see it see the screen OK at night? If you, you either have it in 'night mode' or is faulty. Switch it to Day or Auto.
If you cant see it at night then the Contrast settings may be off. Try adjusting the contrast.
Failing that then there is sadly a fault which ISNT covered by a Porsche warranty.
Good luck,
Rob
