I don't think DFI will make any difference - PCM displays trip info - calc'ed from signals the ECU provides - same PCM unit in the 987 2.9 ( non DFI) engine as the 3.4 and same feature set. There's little magic in the integration - just inside knowledge, the PCM is the same between 997 and 987 - you just code it to tell it what car it's in so it knows to wake up the "rear speaker" features.
The PCCM replicates some (maybe all who knows) of the PCM features, so has a level of canbus integration that 3rd party units don't have - it replicates the trip info stuff and allows basic navigation integration (for the built in nav) with the dash display which is good and a selling point for me - but isnt "hard" if you know the correct canbus messages to look for and to send. . Also - if it follows the pattern for the 9x6 you can bypass the aerial amp in the A pillar and then you use the windscreen antenna for both dab and fm - a win over 3rd party.
Less attractive is the choice of only having USB presentation in the front - even the 9x6 version has a media breakout unit that you can put somewhere - and a rear presented usb - with the option of putting the cable into the glove box or cubby hole would make it look a lot less halfords in use - or even support wireless carplay / AA. Also - I would like it to use the built in mic(s) if the car already had phone prep - but I suspect it will be an additional one.
I think its an opportunity missed - there is likely a decent market for 9x7.2 owners out there who would be prepared to spend that kind of money on a car that still commands a high price, and on the face of it, with the additional "version" being available for the early Cayenne - then its just cosmetics ( and perhaps physical shape of the fascia thats different ) - the Cayennes of the similar vontage to the 9x7 had a PCM 3 variant - exact same unit but it supported bluetooth audio streaming - so increasing looks like a ( flawed) marketing decision to me.
