Hi all, i thought I would share a recent issue.
My 2016 991.2 C2S started dropping a few spots of oil on the driveway , so promptly had a quick look and started my inter web search for reasons.
The reasons were varied and were applicable to both 991.2 and 992 , and covered turbo seals, clamps , oil separators, cool side pipe leaks etc etc.
So the car was booked into the garage for investigation , and the issue being the oil feed to the bearings , no issues with the pipe or the seal , but the torx screw that holds the pipe fitting to the turbo body had corroded through , and was just sitting on top held by the oil, rust and dirt build up .
What was also noted was that the manifold to turbo inlet nuts had all but corroded away, clearly the OEM nuts are substandard.
The good news was that the turbo is fine, as were all of the seals and clamps on the pipework.
Repairs are now underway and car will be back within the week.
I hope this helps others if a leak occurs.
Mark
Mark
