Panamera 2014 V8 GTS
marc.seymour
Good evening I hope you could help I have a judder under braking thought it must be a warped disc. I had all four changed along with new pads and it is still there. It is worse around 50mph and lessens as speed decreases has any of you experienced this if so what was your fix.
Thank you all.
Have you had new tyres fitted if so they need to be road forced balanced
Hi Justin I have had new tyres fitted to the fronts they were balanced on a regular machine. I have not heard of forced wheel balanced until you mentioned it, Googled it and it sounds like it could be the issue I will try that next.
Thanks Marc
I had the same problem on mine I brought new set of wheels for mine had pirelli tyres fitted all round and when I left tyre shop I got vibration from front
It is because if you have a perfect wheel and a perfect tyre it is difficult to balance on a normal tyre balancer so it has to be road forced to get it in balance
From justin
Would be worth checking the ovality of the rimswhen you are at it, as well as the condition of the drive shafts and universal joints but if its only under braking, maybe you should have the brakes looked at again.
Randall
