Paint
- Thread starter u63af
pauljmcnulty
Agreed - check the inside of the sills first to see how advanced it is.ORIGINAL: Fen Sorry to say, but surface rust doesn't really happen on the sills of these cars (unless it has had paint blasted off somehow). It will almost certainly be corroding through from the inside. By all means give it a go, but I suspect if you take a wire brush to it it will turn into lace.
Here it is: [link=http://www.porscheclubgbforum.com/tm.asp?m=194604&mpage=1&key=wurth&#194634]http://www.porscheclubgbforum.com/tm.asp?m=194604&mpage=1&key=wurth&#194634[/link]ORIGINAL: Fen In terms of the stone chip stuff you should use a product by Wurth as that is what Porsche used
morris944s2john
morris944s2john
