scam75
Well-known member
I have traced a slight knocking noise to what appears to be the output bearings in the gearbox. There is 2 or 3mm of out and in play on the bit where the driveshaft bolts onto at the gearbox end, drivers side, and it clicks when you move it in and out. The driveshaft bolts are not loose. The noise is a slight knocking at low speed which manifests itself into a drone at higher speed, seems to go away when turning right. There isn't any play in the passenger side one.
Anyway, what sort of job is replacing the output bearings? Does the box need to come out? Can you get the bearings ok? Do I need a gearbox rebuild?
Car is a 250 turbo with LSD.
Help appreciated!
Stuart
Help appreciated!
Stuart
