Origin b2 GPS speed camera detector
- Thread starter Z80
1) how to find a power feed and were to put the wires.
2) Where to locate the GPS head.
I discarded the cig lighter and used my own similar guage two core wire (ie. two wires one for +ve one for -ve).
If you pull out your radio/CD and disconnect the ISO plug you can tap into the power source. I replaced my
CDR220 yonks ago but my Blaupunkt head uses the same plug. I have attached a pic of the back of the CDR220 FYI.
Socket A pin 7 is what you will use for +ve. This is switched so that it won't be live until your ignistion is on.
Ping 8 is ground and is used for the -ve.
In the line that goes to pin 7 (+ve) ensure you put an inline fuse into your new wiring circuit. If your B2 blows up
you will save your car igniting at the same time!
I fed this wire (the two core) through the back of the dash and along up into the area behind the dash pod. The dash
pos is the batwing thing that contains the speedo/tacho etc etc. I assume you know how to take this off?
It's a 5 minute job. But aske me if you get stuck.
The wire (power source to the Bluei) then pops out behind and to the right of the dash pod. I have some velcro
on the dash so the bluei sits on the velcro and the wires plug into it. I can take it out the car in seconds.
I placed the GPS head (using velcro again) directly behind the flashing alarm LED on the center of the dash. The wire
is fed into the dash pod areas and out behind the pod and to the right. So basically the two wires (power and GPS)
come out together by the velcro.
Viola!
