Opening door on frosty day
- Thread starter ianfiat
GOOFY
Dapster
Secondly - you can (almost) use full throttle straight away instead of waiting for engine to reach over 70C.
I wouldn't do that! It's critical to warm the oil through before you gun the engine.
Regarding the frosted windows, just squirt a bit of de-icer along the edge, taking care not to let any dribble down the bodywork. You can store it in one of the boot cubbies - easier than carrying a kettle around with you!
berty987
Paul Fraser
OLD_Popolou
When running slightly late, i jumped into the car and forgot about the glass being frosted-over. When i reached for the handle all it takes is a little lift and the microswitch activates to drop the window. Oh oh, i thought. But, what i started seeing though was interesting: while the glass was frozen tight to the roof/hardtop it started to'ing and fro'ing automatically until the glass was free. It didn't try to lower then give up as i thought in these cases, but actually started to loosen itself up with a repetitive motion until the glass could lower.
How bloody smart these Germans! Trouble is, i'm sure this is playing havoc with the internals such as the regulator so will be sure not to rush into things again like this again. I don't recall hearing about this behaviour with the 986 so assume it's a new function that occurs during low temps.
Pop
Just apply to any rubber seal very very sparingly (do not get any on your bodywork, its a nightmare to remove) and it will never freeze over/stick again, its waterproof and does not freeze over, it also prolongs the life of the rubber seals. Honda use it on their s2000 roadster, also on most of their old drop tops (crx, s800 etc)
OLD_Popolou
Don't think so. Wouldn't the window just halt in its normal rested position after the first failed attempt since the door handle was released?Popolou- isn't this just showing the microswitches going manic rather than a feature ?
Pop
