Hi, first post, picked up a 944 2.7 in Leicester, from Mike - A9XXC - Got home no problems...Cheers Mike.
Anyhow the plan is to turn the car into a cheap track day car, and see if I like the way the 944 drives before committing to a more expensive 944.
After the drive home last night the first thing I need to tackle is the gear shift quality, to this end I was looking to purchase the short shifter from Only944 in the states along with the shift rod, and sort the lever pivot out myself.
Anyone used this product in the UK?
Next on the agenda a full set Poweflex bushes, to sharpen up the sloppy feel of the suspension, I have used these on other track day cars and find they are a good compromise for a road driven car, any other preferred product any thing I should be aware of that is 944 specific?
I am assuming the front ball joints are in decent order as the car just passed an MOT.
I already have a damaged 944 , would it be worth fitting the thicker turbo roll bars to the 2.7?
Brakes will receive a set of uprated pads (DS2500) or similar along with a fluid change....no need to go mad with brakes at the moment
Engine is to stay standard, just requires a cam and balance belt change.
Finally a set of track orientated tyres on the standard 16" rims.
Is there anything that requires specific attention on the 944 if being used for track days?
