Oil Recommenation
WillJ
Hi,
I know I’m asking the question that is always asked, but i genuinely can’t find it in the forum.
What is the best oil for an 80k mile, 3.2. Also mineral vs synthetic - what’s the difference? Mine has synthetic in currently but don’t know why I would change it.
Porsche recommend a 10w 60 I think but others say it’s not ideal in a cool climate.
All suggestions welcome - ideally please explain why too!!
What oil to use is always like opening a can of worm as you will get hundreds of different views but here goes for my take on it...
Personally think that a 10w60 for this type of engine is too thin an oil and would no put anything less than a 15w..
I have been running Valvoline VR1 20w50 mineral in my SC (having run Mobil1 for years prior to that) and must say really pleased with it (also run it in some of my other more race orientated cars...)
The good thing about the VR1 is that it is a mineral oil and has good zinc and phosphorus content which is really key for our older engines. Being a 20w it takes a little longer to warm up of course, so need to wait a little more before getting hard on the loud pedal but engine runs cooler, doesnt burn oil and not a drip of the floor (which you may end up finding if you use a thiner oil).
Just my 2 pence, no more.
Have had my 3.2 engine in my '73T for 30 years. Was 60K miles old then, now 140.000 miles old now.
Never been apart from the factory build.
The car was hillclimbed hard for 14 years before I changed the car for something far faster, and the 911 became road use only.
I've had the car since 1988.
The late Bob Watson (renowned Porsche specialist) in 1995 told me to use Shell Helix (as it is now called) 10/40 semi synthetic HX-7, and this 3.2 has had only that oil in it every 12 month oil change no matter the miles covered.
In my experience Mobil one is great at searching out leak points on these engines, so dropped that within 3 months of it going in....
You never actually know if one oil is better than another, but if the engine stays together for a long time then the oil used can't be too bad.
I think regular changes is a key to engine wear / longevity. (filter too of course).
Long standing friend of mine swears by VR1, but has the same oil change every 12 months routine.
He has run 2 early 911 cars for 35 years, same as me.
Hi,
check the Mate Slots Australia page
This always comes up because there isn’t one single “right” answer. For a healthy 3.2 with around 80k miles, most people stick with a quality 10W-40 or 15W-50 oil with the correct ZDDP levels for flat-tappet engines. Mineral oils were originally specified when the cars were new, but modern synthetics offer better thermal stability and cleanliness — the only downside is they can sometimes highlight existing leaks. If your engine is happy on synthetic and oil pressure is good, there’s usually no strong reason to change. In cooler climates, 10W-60 can be a bit thick on cold start, which is why some avoid it.
It was a few years ago now since I owned my 3.2 Carrera I used Shell Helix 5/40 I think one occasion the specialist used Valvoline 5/40
I dare say things might have moved on.
I am happy to add my experience.
I purchased my 3.2 over 20 years ago with 105000 on the clock. It had had a top end overhaul at 95000 miles.
I am one of these sad engineers who wants to know all about their cars so when I had it serviced at 107000 miles at JZ Mechtec I asked them to do a compression test. This was out of interest not that I suspected an issue. The figures were lower than expected. At the service JZ Mechtec put the car on to Castrol Magnatec 10W/40 rather than the Mobile One it had been on since the top end rebuild. At the next service at about 119000 miles JZ Mechtec repeated the compression check and the cylinder pressures had gone up.
In discussion with Steve McHale we concluded that the piston rings had not bedded in using the Mobile One oil. The Castrol Magnatec worked better, the rings and seals are all fine at 218000 miles. As I said I am a sad engineer and I record everything regarding this car. From memory I can recall calculating oil consumption of between 1300 and 1800 miles per pint. The annual MOT test always records a HC figure of around 70 ppm (limit is 1200 ppm).
I am confident the Castrol Magnatec 10W/40 is perfect for these engines.
Hope this is of interest.
ALAN
Hello Again
I forgot to say that my 3.2 has an engine oil and filter change every 6000 miles. I do the interim service and it has always used Castrol Magnatec 10W/40 oil. Even when it has its 12000 mile service at an Independent Porsche Specialist (JZ Mechtec, PCT Coventry, Cavendish Porscha) it has been refilled with Castrol Magnatec 10W/40.
ALAN
