It's not a massive job to replace the engine compared with rebuilding it, partly because there is very little you would do when replacing it that you wouldn't have to do in a rebuild as well.
It's not a good first time rebuild proposition though I'd suggest as it has a number of unusual features and traps you can fall into.
Based on the time I've spent with my indie and my car I'd say 8-10 hours would see the engine swapped, but there will be extra time if there are any issues with things like an ECU swap due to loom differences, and if you have to swap ancillaries between engines then that is time, too.
