Oil filter housing gasket leak
andrew.wallis
Hi all, I’m new to the club and group having bought my dream 1990 944s2 carol this summer. Had a persistent oil
Leak which I thought was the balance shafts but having had the belts changed today and balance shaft seal replaced the leak persists.
Garage (local
Porsche specialist) said it was leaking around the oil filter housing and that it was now an engine out job to fix it.
To be honest I’m feeling a bit sick now at the prospect of this level of work required having just spent £1200 on the belts and seals.
Has anyone else had a similar issue and if so is it really an engine out job - grateful for any help/advice or suggestions where I might get the work done in the north of Scotland
Thank you
Hello and welcome Andrew.
Where exactly are you in the North of Scotland?
The engine does not need to come out! I would be avoiding using that establishment again! Exhaust headers need to come off and it would be advisable to have the special Porsche OPRV alignment tool (cheap) and and any semi competent mechanic can do this. See video here:
I'm in Glasgow and could point you to two of my trusted friends/mechanics who I'm sure will sort you out without the need for any internal organs to be sold. One is in Ayr and one is in Blantyre.
Let me know.
Stuart
Hi Andrew, I replied to you post on Facebook.
As Stuart said the engine does not need to come out.
There are many places that oil can leak from, so first off you need to identify exactly where it is leaking. This means thoroughly cleaning the existing oil from the engine and then monitoring it for leaks so you can pin-point the exact area. Oil could be running down from a leak higher up on the engine or for oil on the back of the engine could be coming from the front and running along the pan.
Areas it could be leaking (you mentioned that the front balance shaft seals have been replaced, there are multiple seals, an O-ring, thin opaque washer, and the external seal) - did you also have the front crankshaft seal and O-ring replaced, and the camshaft seal?
Oil pan gasket seal
Lower balance shaft housing or rear O-ring (this is quite common and I don't think your garage would have touched this).
Oil filter seal
Oil filter console seal (a pain to do in situ and it can be done without removing the headers - I've done this myself on axle stands)
Oil pressure sensor and seal
Oil cooler line O-rings
On the S2 - valve cover gasket
Lastly are you positive it is oil? the power steering system is a common leak point also on 944s and makes a right mess.
Just to add to this, a couple of video guides from people that definitely know what they're talking about, now recommend using a sealant called CURIL T on the metal gasket fitted between the consul and the block. As David says, a good clean around the location would be sensible, before a mechanic starts guessing about where to spend your money.
