tom_babbs
Hello all, i am having a long running problem with my car, i keep getting oil in the water, no water in oil (phew) but it is only a matter of time if i am getting it going one way.
The engine is from a 1989 3l s2.
I have changed the gasket where the internal oil cooler would be on the 2.5.
Whilst i did that i noticed that the little bit of pipe that oil goes through didnt project very far into the outer casing, and the gasket set came with 2 o rings which i presume should go on each end of this tube. So i think this is where my problem is.
Anyway i thought i had cured the problem with the gasket but i am starting to get oil in the water again, grrr.
My question is can you get replacement tubes as the one in there was very tight and i fear that if i got pair of grips on it to pull it out i would burr it up and it wouldn't seal.
Should this tube be shimmed out from the block in a similar manner to the oil cooler on a 2.5 in order for the o ring to seal at both the block side and the outer casing? As to me it doesn't look like it is projecting far enough into the outer casing at present.
Or am i missing something else that could be causing the transfer of oil into the water.
Sorry for the garbled rant i hope somebody can help as i don't feel like i am getting anywhere with this car.
Tom
Tom
