The odometer on my 924 stopped working recently for no apparent reason; however the speedo still works.
The Haynes manual does not give any guidance.
Is the only way to fix it to remove the dash, then repair (or more likely) replace the speedo ?
Is there are any else to check before I under take this (and is this job better left to a porsche specialist you has probably changed may speedo?)
BTW, as far as I can make out a non-working odometer will not cause an MOT failure - can anything confirm this ? (I'm still going to fix it but it removes some of the urgency)
John
John
