My 73T has had this 3.2 in it since 1994 and it is faultless. It has never been apart, maintained to death over the years.
Over all those years I've got used to the way it starts and this 'sound' has never changed unless one of the batteries fails, which has happened twice, once about 10 years ago and second time a month ago.
On one battery the starting 'churn' is labloured, but the engine would fire and run a treat.
Every time.
Hot or cold.
I replaced the dead battery of the pair (about 10 years old) with an identical Bosche silver unit, same rating as the other good one, thus one battery is old, the other new.
Charged the car with my new charger until 'full'.
This was a few days ago.
Came to start the car this morning for a longish run to a local hillclimb.
Turn the key, press the start button ( a mod made about 3 years ago) and the engine churned over with some speed, far quicker than before, but the usual few seconds passed and 4 secs later the engine started, ran perfectly.
It has never delayed to start ever. I never touch the throttle when starting.
Starting from cold again to drive back from deepest Shropshire, the same quick turn-over and the delay to fire was slightly longer, about 5 sec. Ran perfectly.
The only thing to have changed is the battery replacement and the full charge.
I can't see why a fresh battery added, a full car charge (didn't take very long) would lead to a longer than usual time to fire.
I guess the car would not have max volts in the past, but that would make the delay worse?
The engine is about 140K miles, E5 fuel, stock DME Bosch controller.
1000 rpm tick over (as always), 180F engine temp fully warm and certainly on all 6.
Any thoughts?
Will start it again tomorrow to see if it delays again
73T 911
Every time.
Hot or cold.
Any thoughts?
73T 911
