not starting
deafasapost
hi guys, went to turn over the s2 cab and its not starting.
i am getting a strong bounce on the tacho, (battery fully charged from the trickle charger) and it did catch twice but wont run.
.could it be DME? or FPR?
i'll try some fresh fuel first and see if that helps.
the car has been started whilst in the garage, the last time 10 days ago and fired up the the first turn of the key. battery is fully charged and as stated above, it did catch but wont start and run.
any help guys?
cheers, Al.
took the dme out and give it a tap, put it back in and started first turn, so looks like the dme is on its way out. i'll order 2 from the opc as soon as.
even better is to modify a duff DME relay by joining terminals 30, 87 & 87b to make it a 3x way bypass and keep that in the glove compartment[;)]
