non stop fan
- Thread starter Guest
The fan may come on when the car is first turned off usually due to heat sink and shouldn't remain on for more than aprox 5 minutes. As far as I understand there are two fan speeds on the 'S', with high speed kicking in as the needle reaches the upper end of the upper mark of the gauge (before the red sector).
The heat switch in the radiator is cheaper to buy and range in price from 10 pounds through to 30 pounds. You will need a heaft size socket wrench though as it is over 24mm. And don't over toque it. I don't have the torque setting to hand right now though.
The replacement proceedure is on this website under 'garage manual' , then "thermo switch"
Clarkes Garage
Although it is pretty simple to undertake, just don't over torque it or cross thread it. Radiators are not of the most robust materials.
eastendr
ORIGINAL: golfchampion
Got a problem!The fan does not switch off when the engine is off! Checked relay and the fan still remains on.Could it be the temperature sensor or something else? Cheers Tom.
Mine did the same a couple of years ago (944S). Temperature sensor in the radiator. It's got 2 spade termainals. If you pull one off, the fan will stop to prove the problem.
Cheap part from Eurocarparts and easy to replace. Make sure you bleed the system properly afterwards ...
HTH
Rick.
danmason
Mine did the same a couple of years ago. Temperature sensor in the radiator. It's got 2 spade termainals. If you pull one off, the fan will stop to prove the problem.
ditto
Cheers!
