Can anyone help. It worked one day then the next day would not start, checked everything, conclusion I could not hear the fuel pump start to prime the system when I turned the ignition key. I have checked the relay wiring as per Haynes manual and it is all ok. I put another relay in but still no click and yet there is voltage at terminals 15 and 31 which should close the relay but it doesn't. Now I am getting peeved as this one is beating me. Can anyone tell me the voltage at the relay board to close the relay and if there is anything else I should be looking for in the wiring like aux air valve and cold start. The car is a 1979 model 924 with 39,000 miles on clock. Ta.
![Spanner 5 [sm=spanner5.gif] [sm=spanner5.gif]](/forum/styles/default/pcgb/spanner5.gif)
