George Elliott
Absolutely agree.
Terry,
The sill definition I use is "from under the lower rear edge of the front wing to the back wheelarch edge" (which is why the wing needs to come off to do it right)
The Sill Porsche supply is better defined as " the bit of the sill below the door" as can be seen in the ebay images above.
The fabrication answer is, yes - unless you make up the bit from the door to the wheelarch you dont have a complete replacement sill. And when you do this there is a weld seam to join this into the Porsche sill, and another to join it into the quarter. All the seams will be a corrosion challenge.
George
944t
Absolutely agree.
Terry,
George
944t
