Noisy tappets
- Thread starter barks944
mr brightside
mr brightside
When i start up the car from cold it sounds like i've got and old man sat under the bonnet playing the spoons for a couple of moments until i get full oil prerssure. The rest of the time it just ticks on maybe one tappet, but from cold the noise is flipping cringeworthy. Any opinions?
RevEm
mr brightside
JamesO
Hilux
More than likely. [link=http://www.porscheclubgbforum.com/fb.asp?m=286351]http://www.porscheclubgbforum.com/fb.asp?m=286351[/link]If i remember correctly it was the check valve between the head and cam box sticking, allowing the oil to drain from the cam box when the engine is off. When I changed the headgasket, cleaning the oil sludge solved the problem.
Are you using the same oil? with a good synth mine stays close to 5 unless really (track day) hot, with lesser oils it drops when warm to around 3.5 TonyORIGINAL: mr brightside Mine only happens when it's cold, it's like the oil is not getting there fast enough. Strangely it started shortly after i'd flushed the engine for the first time after i'd got the car. It was also accompanied by a general drop in oil pressure, the car used to run at 5 Bar all the time and over successive flushes this has dropped to 3.5 bar when warm. It's as if i've flushed out all the carbon that was keeping it quiet.
