Noisy Rear Wiper
- Thread starter wizard
steve 944t
Although it would be better if it had speed settings and actually wiped in the area the driver views
I agree it is on the wrong side for right hand cars.ORIGINAL: scz
also I consider it to be on the wrong side.
I have just got a donor wiper to mess about with. The problem is that the axis point should be another 10cms to the right so it would sweep in the correct area.
Of course you can't drill another hole.
You can I believe get an inch longer wiper than the twenty which would help slightly (that would make it twenty one inches in total, in case you fell asleep). I put some longer ones on the front but the extra length went bottom side as oppose to top, therefore if the rear was the same it would not make any difference.
It would also be possible to extend the arm itself by a couple of cms.
Thirdly, you can move the axis.
What I was looking at, is to cam the arm so it would extend on the sweep. It may be possible to use something from another vehicle.
Look at these blades http://www.spectrumblades.co.uk/ v. expensive mind. Rice or nice?
Have I just said all that out loud?[
Wizard, it's easy to take the cover off and you may get a better idea of what is causing the noise. It's not the blade itself is it? (said trying to keep on thread) There seems to be a couple on ebay at the moment.
Just got to work out a delete for the rear washer jet[
Darren - I have taken the cover off and sprayed silicon lube in there, but had no effect. It's so loud that trying to determine where it comes from is impossible.
The noise is definately from the motor, I can't think of how to describe what it sounds like but it is very loud and passer bys give you strange looks!
I will probably wait for it to pack up now then delete it.
http://www.arnnworx.com/
jez_anderson
Did you manage to quiet it down any or did you take it out?
jez_anderson
jez_anderson
mik_ok
ORIGINAL: flamingeye
I would just like to say, I'm a fan of the rear wiper! (like the sunroof)
I'm a fan too.
I put a 24" wiper on the rear. Looks fine, fits no prob and (obviosuly) clears a far larger area. The original was rubbish, but this makes it at least useable.
Not the best pic, but gives you an idea CLICK You might even squeeze a 25" wiper on there (if you can get them?).
Being a pedantic old git, a blade an 1 inch longer will only add 1/2 inch to the sweep.
Siggy
I'd be happy even with an extra half inch wiping over my rear [ORIGINAL: Siggy
Siggy
I have replaced the rubber washers on mine as they were abit worst for wear. I noticed when it was stood in the rain, it would leak slightly. [
Siggy,
What is your S2 look-a-likey like?
Tony
