scam75
Well-known member
Last few weeks 2nd been getting more notchy and harder to get into reverse and gear stick not exactly great! Recently fitted a new front shift lever so inspected that and all was good at the cabin end. Loosened the 2 x 13mm bolts to try and adjust and it got worse and worse till the point I couldn't select a gear.
I haven't inspected the gearbox end yet, dark and wet and car lives outside, but having looked at images I took of my new box and the short shift rear linkage on it, my money is on the bolt been working its way loose that connects the linkage to the shift lever on the box, the one that seems to have 2 x 13mm nuts, and 2 x large washers on either side of the gearbox shift lever, if that makes sense to those who are familiar!
I'm also hoping that as it finally gave way on the driveway, anything loose or fallen off shouldn't have got far. Weather looks fair tomorrow so will get it up on axle stands for inspection.
My question is, is that nut and bolt and washer set-up anything special? Can it only tighten so far so as not to crush the washers too close to the gearbox shift lever? I can't tell from the pictures I took.
Thanks in advance as ever!
