Fen, thanks for finding the right words. I agree with you.
  I haven't looked into 15" wheels as grip would be even less good than with 16" and 16" is the original size. I also believe it won't be easy to find a 15" 245 or wider tyre.
 Although grip is obviously a factor to look for, too much grip can actually alter the dynamics of a chassis, and having tested many suspension set ups on 944 (Bilstein Cup, KW, Moton, Konis, Bilstein B6), in any case the best compromise, or maybe should I say the one that I consider best, was reached with 16" wheels.
 I firmly believe a minimum amount of tyre "slippy-ness" is needed to make the dynamics of a chassis work correctly, this slippy-ness not necessarily being noticable to the driver in extreme conditions such as heavy cornering and weight transfers.
 In order to improve grip we could obviously go mad and fit ultra low profile tyres with 18" or even bigger wheels, however it won't make the chassis work correctly and although this will make the car virtually impossible to lose in a corner it may not make it lap a track faster.
			ORIGINAL:  Hilux
   why is the fitting of of 968 castor bushes highly recommended when running 17 wheels?
  Funny you should mention that ... Look at the following picture [
