Chaps,
A slightly odd one. I know there are some chaps on here who know a LOT about 944 chassis dynamics, so I'm keen to hear your opinion.
I had some new rear tyres put on my S2 last week. It did have Falken FK452's all 'round, and I replaced the rears with Kumho KU31's (they were on special offer and come well recommended on this forum). The old rears were worn, and borderline legal. I had an advisory on an MOT and they needed to be changed before winter.
Since the tyres were changed, the handling of the car is not as it was. It feels very well planted at the back (where the new tyres are), but the front feels less stable and almost a little wayward. The impression is almost that of understeer, certainly of slight lack of control. It's not that it doesn't turn in as well as before, more that it doesn't inspire confidence in the front-end handling in the way that it did before. The sensation is very similar to that of a broken front ARB mount, but I have had it up in the air and checked carefully around the ARB's and there is no sign of anything amiss.
I suspect that the car wasn't jacked correctly when the tyres were fitted; the jack on the drivers' side wasn't well positioned, and looked like it wasn't on the central jacking point as it should be, but I am not 100% confident about this. (I wasn't allowed into the tyre fitting bay when the work was done - the garage owner was a to55er of the first order, and I won't be going back there again. PM me if you want details.) However I have inspected the jacking site carefully since the work was done and there is no sign of anything amiss there either (no damage to paint or shape), so I could be wrong on this point.
I also know that the lower balljoint on the O/S/F wishbone is worn, and needs replacing. However, this was the case before the tyres were changed, so I don't expect it is a contributing factor.
Has anyone else experienced anything like this? Is is a common (or even known) complaint? The car needs a full geo check, which will be done in the next couple of weeks (after the wishbone is replaced) and I will be able to see if there is anything amiss in terms of alignment then.
All comments welcomed.
