New Battery Needed
- Thread starter BlueNGT
http://www.eurocarparts.com/ecommerce/Search_Results.asp
**Although it is listed here as 45Ah - does that mean it has more 'juice' for cranking the engine after longish periods left standing?
Des, I guess the RS only needs 36Ah because of the lighter flywheel?
BlueNGT
ORIGINAL: Tony
I'm with Des on this - definitely Halfords - 3 year warranty which they honour - but do keep the receipt!.
Seems to be an HB 063 whatever amperage that might be.
Tony
I was going to go to Halfords but a friend has put one of theirs in his RS and he reports it doesnt idle as well as it did.
I've emailed a friend at Porsche with the correct RS (999 611 036 20) part number to see what the cost might be from them. Also Costco sell Bosch and have a guy phoning Bosch technical for me to find out about the 36 Amp/hr availability.
Is it dangerous to put a higher amp/hour battery in the car?
What minimum cranking amp is needed?
jr2015
jr.
BlueNGT
ORIGINAL: jr
Installing a more powerful (higher AH value ) battery is not dangerous provided it`s 12 volt, and it will crank over the engine better in really cold weather, but physical size usually increases and it may not fit the available space. The RS models have much less electrical equipment than the standard models so a smaller AH battery is acceptable and probably weighs less which is why all the elecrtical stuff was chucked out in the first place (weightsaving)
jr.
There was a Bosch 45 amp/hr, with 420 CCA in Costco. Same dimensions as the one in the car now, so that is better?
rskiwi
The reason the car will not idle properly is that when you change the battery you should let engine idle for 15 mins to reset the electronics. Have a look in the handbook!!ORIGINAL: BlueNGT
ORIGINAL: Tony
Tony
