New 944 owner
- Thread starter Masher
944 man
edh
944 man
They do. S2 doesn't stand for series two - this is the root of the confusion. Series one cars have 924 dashboards and steel suspension. Series two 944s replaced these in September 1985 for the 1986 model year. These cars have the 'oval' dashboard, flush fitting windscreen, aluminium suspension arms and manifold other changes. The 1986 model years cars share the series one cars chassis dimensions and ABS was not available. The 1987 model years car added ABS and the offset changed from the earlier 23.3mm to 52.3mm. The 944S was launched for the 1987 model year, with the S standing for Super. It wasn't particularly super though so they tried harder and mixed a larger capacity but otherwise broadly similar 16v engine with the chassis and revised body from the Turbo, making the S2. So: series two and S2 refer to completely different things. The S2 is a series two car, but so is yours. /education [ORIGINAL: Masher Clearly I need educating. I thought the S2 cars had the one piece nose / front bumper. I'll do more homework and thanks for pointing me in the right direction. Mick
nicksonmsport
edh
Don't worry about that - The drivers no good! There is an oil cooler located just to the inside of the power steering cooling coil with a hole cut in the front valence to allow air to it. Looks like a recipe for a stone through it currently so I will manufacture a mesh in due course. The standard rad was replaced and attention has been taken to ensure good cooling - I guess I'll find out on the track when it's 30 degrees (clearly a foreign track day!). The 924 turbo style hump feeds air into the general bonnet area above the turbo so does serve a function beyond addressing my mid life crisis! Be sure to say hi at Bedford, MickORIGINAL: edh I'll be waving you past at Bedford []
Steve Brookes
Moderator
944 man
