GlennS
OK... here are the symptoms.
1. Nasty buzzing noise heard which appears to be emanating from somewhere to the rear of the engine. Occurs when ignition switched on.
2. Engine cranks but no movement from rev counter.
3. Occasionally, nasty buzzing noise will stop and engine will start at that point if cranked. Will run for a little while and then cut out to the accompaniment of "the return of the buzzing noise".
4. DME relay has been changed for known-good replacement. No improvement.
Suspect "sensor problems". Please advise!
