N rated tyres - manufacturers ?
- Thread starter Guest
Michelin
Dunlop
Pirelli
Goodyear
Yokohama
Bridgestone
Continental
I think that's it. Not all manufacturers make tyres in all sizes for all models though.
http://www.porscheclubgbforum.com/tm.asp?m=172418&mpage=1&key=rated
I would imagine the manufacturers would be the same for N rated ones for the Boxter
Pete
ORIGINAL: Oxtailsoup
Does anyone know what the difference is between the Continental Sport Contact 2 N2 and the normal Continental Sport Contact 2? They look the same to me but I presume there is a subtle difference somewhere!
Are you asking what is the different between a N rate tyre and the equivalent tyre for all other cars?
Well, see my comment on new Michelin Pilot Sports 2 (last paragraph in the link below) which would apply to the new Contis too:
http://www.porscheclubgbforum.com/m.asp?m=204589
Tread patterns look similiar to me on the Conti's (N and non N)
The whole thing about Porsche tyres seems to be a minefield! Or should I say tyres for your Porsche.
As I mentioned, modern tyres are exactly the same visually i.e. tread pattern wise for N and non N, so it could be either now those manufacturers design a new tyre get then N rate them and finally use the benefit of Porsche testing to make all high performance tyres.
It doesn't have to be a minefield, well at least for modern Porsche built after the N rating was introduced; if they are the same visually then just think of it as you get tyres with a special N and you know in most case they were specifically tested on your Porsche model. Hope you read the link on the N rating in my thread which explains everything.
ORIGINAL: Mark Bennett
As the price difference seems to be only a couple of Pounds, I'd stick with the N version.
At Costco, the N rated Michs are actually a couple of Pounds less (than non-N rated)!
Edit: For 986
oceancarrera
ORIGINAL: fatcat
Also:
Toyo - Proxes T1-R
Really? I don't ever remember these being available in N-rating?! T1Rs were a good tyre, but the sidewalls are still a bit soft...
