MY03 Onwards Noises from Roof
- Thread starter JCB..
ORIGINAL: JCB..
Hello all
I have a query regarding what is described as a 'flapping' noise
JCB..
Can't remember if there was any solution other than the OPC taking the roof apart and doing something?
It should be under warranty though?...
GreigM
1) OPC reading have an official fix, involving inserting foam
2) There is a DIY fix to sort out some of the cabling - try a quick search on boxa.net.
I intend to raise the issue again very soon with the OPC.
I raised it with my local OPC (Glasgow) and they tightened the roof, but this made no difference.
I then mentioned it to another OPC whom had previously cured the problem with a foam insert in the roof, however the problem seems to have re-occured in the car again. I like Greig am led to believe Reading OPC have also fixed it, but dont know if their fix is still 'working'.
Brian J
My 03 boxster's roof always creaked and squeaked . Went back twice to opc they said they had adjusted the deck and lubricated any parts that needed it. All was well for a few weeks until going over uneven ground, and the groaning and moaning always returned.
Never experienced any noise on my first 97 Boxster.
Just keep taking it back under warranty untill the matter is resolved.
Now sold my 03 boxster. squeaked right up to that point, guess the new owner will have to try to and get it sorted .
Could it be the glass rear window model that only suffers?
Regards Cliff.
