Porka944s
A month or so back i developed a problem, my lights went down and didnt come back up, they would switch on in both stages but stay down, my dash lights also got stuck on and drained the battery.
I took it to an independant who took 2 weeks to spend one hour looking at it, they tried a new ignition and a new light switch, fortunately it was neither so all i owed them was an hours labour.
Im an engineer by trade but cant ever be arsed to fiddle with things like this, but i got the hump paying 60 odd quid an hour for them to bumble through with it. So i thought id have a look.
Thanks to you guys a got a pdf of the wiring diagram, and started thinking. A few weeks ago i checked fuses got sidetracked, and have been driving around, relay out lights wound up, but tonight i decided to have a look as id been thinking about it and thought i worked it out.
Unfamiliar with some symbols on the diagram i came to the conclusion that the headlight motor has positonal contacts. motor drives one direction only so it drives till it hits one contact, stops, then drives to the next contact and stops for the down position. I reckon when it went wrong intertia of the mech drove it past where it was supposed to stop, shorting the dash lights on, and making the circuit unable to get to the position it needed to drive up. After winding the lights up a few times and switching the ignition on with the light switch off, it finally drove to the correct stop position, now they are working again. So a warning have a fiddle first, trust your instincts it may end up cheaper.
