bumperblue
Hi,
Hoping to find a electrical knowledge base out there. I am quite good with the mechanical side but, a novice on electrics.
The car '91 944 S2
The problem. At sometime the flash function on the headlamps has stopped working. When the lights are popped up the dipped/main beam works correctly but, if I was in dipped mode and pulled the stalk towards me it used to flash the mains now it doesn't. Similarly when the pods are retracted and you pull the stalk towards you the auxillary driving lamps flashed now they don't.
Any pointers any one. I am a bit perplexed as you can switch between dipped and main isn't it same mechanism?
Thanks in advance
Regards,
Ian
The car '91 944 S2
Thanks in advance
Regards,
Ian
