markstephens
Hello I have been busy rebuilding the bodywork of my 993 for the last 9 months but today I decided to take it for a blast up the road ( for the very first time )
I drove it for about half a mile and decided to give it sum, anyway to my horror in my rear view mirror all I could see was smoke , I switched off the engine and had a look too no avail so I drove it back home very slowly, the car was pumping out smoke, anyway I got home checked to see the problem and found oil running out on to the floor.
I stripped down the air filter and found oil in the filter and oil in the air flow sensor.
I then checked the oil which was very very full, I havent checked the oil level before dont ask my why because I know its a basic thing too check.
I cleaned up the oil on the engine that had overflowed and started the engine again to see if I could find the source of the problem, the engine stopped smoking and I could not find any leaks the engine ran almost normal a little lumpy.
I then undid the oil filler cap too find oil running out of the filler pipe?
Is the problem simply that the engine is overfull with oil or could it be something more sinister
Any advice would be appreciated.
