Hi all,
I’ll try to keep this short but in all fairness I’m staring into the abyss and this thread could go on!
First off the run down of my 944 and what I know. It’s an ’84 NA 944 2.5 LUX.
She’s currently at around 75k on the clock and since purchase the temperature has been a bit a little erratic. The story goes that the car was laid up for around 8 years before a guy who I bought I from, purchased it and spent over £1000 on it, getting running right. Full belts (incl water pump), fluids, terra-cleaned, brakes, fuel lines, quite a lot happened. He ran out of time and patience I guess.
I ran her up to north Wales once and I think that finished it off. It may have been a combination of things but the result was over pressurisation of the coolant system, distinct smell of fuel and poor power at times. I did change the thermostat for a genuine one and drained and flushed coolant and that did seem to help a bit. But there were more signs the head was on the way out, so after much scrimping last year, I bite the bullet and have just had the work carried out.
With the work done, she runs well but unfortunately, still warm. Not over heating apparently but close enough for the fan to want to fire up too often, even at this time of year.
The details to add here are the fact that I had to buy a new head from the garage because mine had been previously repaired and had badly corroded. The mechanic noted that in some of the galleries of the engine, corrosion could be seen, so obviously this has to be considered in the bigger picture.
Broke and obviously a little disheartened, I have to plough on. Word from the garage was that it’s a resistance in the cooling system causing this overheating. I need to rectify this situation ASAP if I don’t want to see the head fail again.
I’m putting this thread up because I’d like to hear some experiences and just general thoughts on the matter to keep me sane. The history of the car isn’t extensive but all round she has good body work and has not been modified.
The advice has been to start the process of elimination again, perhaps starting with the oil cooler and the rad. I’d like to just through more money at it but it’s already looking like a soup and noodles month. [s2]
